This page provides information about the V-Ray Atmospheric Effects render element in Cinema 4D.
width62%
The Atmosphere Render Element stores only atmospheric or volumetric participating media such as fog or Aerial Perspective. This render element can then be used to enhance or color-correct just the atmospheric component of the image during the compositing process.
When atmospheric effects or fog is included in a scene, they will render into the Beauty|RGB channel, and should also be output as the VRayAtmosphere channel for compositing use.
UI Path: ||V-Ray|| > Render Elements > Atmospheric Effects
width5%
width33%
Properties
width62%
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color MappingApplies the color mapping options specified in theColor mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Filtering –  Applies an image filter to this channel.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width33%
