This page provides information on how V-Ray integrates into the standard Cinema 4D menus.
V-Ray provides a menu on its own in Cinema 4D's toolbar, where you can find some commonly used V-Ray components.
In addition, there are a number of items to the Cinema 4D menus, in particular in the Preferences and Create menus.
width57%
V-Ray VFBOpens the New V-Ray Frame Buffer window.
Start Interactive RenderStarts Interactive render in the VFB.
Start Production RenderStarts Production render in the VFB.
Render ElementsOpens the Render Elements window.
LightsOpens the Lights submenu.
CamerasOpens the Cameras submenu.
GeometryOpens the Geometry submenu.
Volumetrics Opens the Volumetrics submenu.
HelpOpens Chaos Group documentation online.
width5%
width38%
width57%
Rectangle LightCreates a Rectangle Light.
Sphere LightCreates a Sphere light.
Dome LightCreates a Dome light.
IES LightCreates an IES light.
V-Ray SunCreates a V-Ray Sun.
V-Ray Sun with SkyCreates a V-Ray Sun and Sky system.
width5%
width38%
width57%
Physical CameraCreates a Physical camera.
width5%
width38%
width57%
V-Ray ProxyCreates a V-Ray Proxy object.
width5%
width38%
width57%
Environment FogCreates an Environment fog.
width5%
width38%
width5%
width45%
Edit > Preferences > Renderer > V-Ray
width45%
width5%
width5%
width45%
 Create toolbar > V-Ray
width45%
Create > V-Ray
width5%
