The .vrscene file format is an ASCII file that can be exported from Cinema 4D and other platforms that use V-Ray. It contains all the information about the scene such as geometry, lights, and shaders, and can be rendered with the V-Ray Standalone. Additionally, .vrscene files from any V-Ray platform can be imported into V-Ray for Cinema 4D. This functionality can transfer lights and entire assets with their textures and materials between V-Ray platforms, while animation is also included.
Exporting V-Ray Scene Files
- If you do not want to render your scene when exporting the .vrscene, disable the Render option.
- Enable and expand the Export to a. vrscene file rollout.
Set the directory and the name of the file in the File field below.
Section Column width 25% Column width 50% Column width 25% - Click on the Render button () to save the .vrscene.
