width62%
V-Ray Additional Attributes can be added to any Bifrost simulation from the Attributes > VRay menu menu in the Attribute Editor. These additional attributes assist in exporting.
Anchor
legacy
legacy
With V-Ray 5.0 the Maya Bifrost renders physically correct, i.e. it appears darker. The original look from previous V-Ray versions can be replicated by adding the V-Ray fluid legacy Phoenix FD shading attribute and then turning on the Legacy Phoenix FD Shading option. See the Rendering with Older Assets page.
UI Path: ||Select Bifrost system|| > Attribute EditorAttributes menu > VRay > (select attribute set)
width5%
width33%
