width57%
V-Ray VFBOpens the New V-Ray Frame Buffer window.
Start Interactive RenderStarts Interactive render in the VFB.
Start Production RenderStarts Production render in the VFB.
Render ElementsOpens the Render Elements window.
LightsOpens the Lights submenu.
CamerasOpens the Cameras submenu.
GeometryOpens the Geometry submenu.
Volumetrics Opens the Volumetrics submenu.
HelpOpens Chaos Group documentation onlinethe Help submenu.
width5%
width38%
width57%
Environment FogCreates an Environment fog.
width5%
width38%
Image Added
width57%
AboutOpens an About window.
Online DocumentationOpens the V-Ray for Cinema 4D documentation in a browser.
Online Help CenterOpens the Chaos Group Help center in a browser.
Check for UpdateChecks if a newer V-Ray version is available for download.
width5%
width38%
Image Modified
width57%
The About window contains information about the current V-Ray version installed, copyright notice and information if this is the latest released version or there is a newer update available for download.
width5%
width38%
Image Added
width45%
Edit > Preferences > Renderer > V-Ray
See more information at the Preferences V-Ray Menu page.
width10%
width45%
width45%
 Create toolbar > V-Ray
width10%
width45%
Create > V-Ray
width45%
You can access V-Ray log from Extensions > Console > V-Ray
width10%
width45%
