The Diffuse rollout is part of the Generic material's parameters.
Diffuse
width60%
Some options are available only in Advanced mode.
Color – Specifies the color of the material. For dielectric materials this is the diffuse color. For metals this is the specular reflections color.
Diffuse Roughness – Controls the Diffuse BRDF Falloff. It can be used to simulate rough surfaces or surfaces covered with dust (for example, skin or the surface of the moon). Note that this parameter only affects the diffuse portion of non-metallic materials. For more information, please see the Roughness Parameter example below.
width5%
width35%
Anchor
Roughness Parameter
Roughness Parameter
Example: The Roughness Parameter
This example demonstrates the effect of the Roughness parameter. Note how, as the Roughness increases, the materials appear more "flat" and dusty.
bordertrue
width30%
width40%
Image slider
Panel
borderStylenone
Roughness = 0.0 (regular diffuse material)
Panel
borderStylenone
Roughness = 0.3
Panel
borderStylenone
Roughness = 0.6
Panel
borderStylenone
Roughness = 0.8
width30%
width30%
UI Text Box
sizemedium
See next:
Generic Reflection
width70%
