This page provides information on the V-Ray UVW Texture.
width60%
The UVW texture can be used to illustrate the UVW mapping of object faces. It is usually combined with the Extra Texture render element.
Note that UVW texture produces proper results when the material is applied to the object's faces instead of a group/component or a texture projection tools are used. See UV Tools for more information.
UI Text Box
typetip
Any texture can be replaced via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
width5%
width35%
UVW
width60%
Component – Specifies which component to show.
U
V
W
width5%
width35%
Multiexcerpt include
MultiExcerptNameTexture Placement
PageWithExcerptBitmap
