This page provides information about the V-Ray Scene Importer tool in V-Ray for SketchUp.
Section | |||||||||||||||
UI Path
The VRscene Import Options window is accessible through SketchUp's main menu File > Import. Select a .vrscene file and find the Options... button at the bottom of the browsing window.
Section | |||||||||||||||||||||||||
VRScene Import Options
Usage Example
This example demonstrates the import of a .vrscene from 3ds Max. The first picture shows the scene and the render in the VFB. Once imported in SketchUp, the render is the same. The import is done with Texture & UVs option for Materials and the scale is preserved as in the original project.
Note that the bonsai model is a Proxy Mesh which remains a proxy in SketchUp after the import process is complete.
The scene in 3ds Max and the render in VFB
The imported .vrscene in SketchUp and the render in VFB
UI Text Box | ||
If particularly small faces are missing from the imported scene, delete the component and repeat the import process with increased scale value. |
Footnotes
Anchor | ||||
- Light textures are currently not supported. If a .vrscene file contains a light with slotted texture map, upon import the texture will be lost.
2 – When a vrscene with instanced light is exported and then imported, it is imported with multiple separate assets, instead of one. Anchor 2 2
