Single executable that runs without Administrative privileges and without Internet connection*
Free software - V-Ray license is not required
High DPI support
Known Issues
Fancy Bullets
type
circle
OS UI may be sluggish during GPU benchmark
GPU CUDA devices could be enabled/disabled from NVIDIA Control Panel only
Display of buckets in CPU rendering could be slower than the actual rendering on many-core machines. Even if it is - timing will be correct and will finish before drawing.
If there is a proxy you should set: LAN Settings > Bypass proxy server for local addresses - should be turned ON
