V-Ray 5 for SketchUp licenses also work with V-Ray Next, allowing anyone who purchases an upgrade to complete unfinished projects using V-Ray Next if needed.
UI Text Box | ||
Please note that V-Ray for SketchUp is supported only for V-Ray 5 and V-Ray Next (V-Ray 4). Earlier versions are no longer supported. |
Lights
The Portal Light option in V-Ray Rectangle light is now a legacy option and is no longer exposed in the UI. Rectangle lights in files saved with previous V-Ray versions and this option enabled will still have it available. Regardless, for best performance consider disabling it and using the Adaptive Dome Light option instead.
