The Sheen rollout is part of the Generic material's parameters.
Sheen
width60%
Available only in Advanced mode.
Sheen Color – Specifies the color of the sheen layer. Black color disables the effect.
Sheen Glossiness – Available when the Surface control option is set to Use Glossiness. Controls the sharpness of reflection. A value of 1.0 means all of the light reaches the diffuse color, whereas when the value is smaller, the cloth material looks glossier. See the Sheen Glossiness example below.
Sheen Roughness– Available when the Surface control option is set to Use Roughness. Controls the sharpness of reflection. A value of 0.0 means all of the light reaches the diffuse color, whereas when the value is higher, the cloth material looks glossier.
UI Text Box
typeinfo
The Sheen layer can be used for creation of cloth materials, such as satin. It is a top reflective layer to the diffuse color.
width5%
width35%
Anchor
sheen
sheen
Example: Sheen Glossiness
This example shows how changing the glossiness parameter of the sheen layer affects the material. A smaller value makes the sheen layer reflect most of the light. Increasing the value allows more light to reach the diffuse component.
width25%
width50%
Image slider
Panel
borderStylenone
Sheen Reflection = 0.1
Panel
borderStylenone
Sheen Reflection = 0.3
Panel
borderStylenone
Sheen Reflection = 0.5
Panel
borderStylenone
Sheen Reflection = 0.6
Panel
borderStylenone
Sheen Reflection = 0.8
Panel
borderStylenone
Sheen Reflection = 0.9
Panel
borderStylenone
Sheen Reflection = 1
width25%
width30%
UI Text Box
sizemedium
Previous:
Generic Coat
width40%
width30%
UI Text Box
sizemedium
Next:
Generic Opacity
