If you are not familiar with using Light Path Expressions (LPEs), this page is a good place to start. The sections below will try to explain what LPEs are, how they work and what are the possible use cases.
UI Text Box | ||
The Advanced Light Path Expressions article goes into greater detail about complex LPE usage and concepts. |
What are LPEs?
Light Path Expressions are a special type of render element with advanced capabilities. They use regular expression patterns to record selected events of light contribution along the path of a ray.
Section | |||||||||||||||||||||||||||||||||||
