This page provides information about the Generic material in V-Ray for Revit.
Generic is a special V-Ray material, that allows for better physically correct illumination (energy distribution) in the scene, faster rendering, more convenient reflection and refraction parameters. Within this material you can apply different texture maps, control the reflections and refractions, add bump and displacement maps, force direct GI calculations, and choose the BRDF for the material.
UI Options
Example: The Roughness Parameter
This example demonstrates the effect of the Roughness parameter. Note how, as the Roughness increases, the material appears more "flat" and dusty.
borderStyle | none |
Roughness = 0.0 (regular diffuse material)
Panel | ||
Roughness = 0.3 |
Panel | ||
Roughness = 0.6 |
Panel | ||
Roughness = 0.8 |
Column | ||
Reflection
Section | |||||||||||||||||||||||||
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Example: The Anisotropy and Rotation Parameters
This example demonstrates the effect of the Anisotropy and Rotation parameters, which determines the shape of the highlight. For the examples below the Type was set to Microfacet GTR (GGX).
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Dim Distance
Example: The Fresnel Option
This example demonstrates the effect of the Fresnel option. Note how the strength of the reflection varies with the IOR of the material. For this example, the Reflection color is pure white (255, 255, 255).
Refraction
Dispersion
Fog Scattering3
Attributes
The attributes available for the Generic material are as follows.
Anchor | ||||
Translucency
Bump
Contour
Displacement
Column | ||
width | 45% |
Example: The Fog Multiplier Parameter
Image slider | |||||||||||||||
Column | |||||||||||||||||||||||||||
Example: The Refraction IOR ParameterThis example demonstrates the effect of the Refraction IOR parameter. Note how light bends more as the IOR deviates from 1.0. When the index of refraction (IOR) is 1.0, the render produces a transparent object. Note however, that in the case of transparent objects, it might be better to assign an opacity map to the material, rather than use refraction.
Column | ||
Raytrace Properties
Override
Material ID
Example: Dispersion
This example demonstrates the Dispersion capabilities of the V-Ray material and the effect of the Abbe parameter.
Each Generic rollout has its own dedicated page listed below:
Opacity
Multipliers
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
For all other material settings, see the Attributes section on Materials page.
Fancy Bullets | ||||||||||||||||||
