width65%
Available only in Advanced mode.
Coat Amount – Specifies the blending weight of the coat layer. A value of 0 does not add a coat layer, while higher values blend the coat gradually.
Coat Color – Determines the coat layer's color. A texture map can be used here.
Coat Glossiness – Available when the Surface controlControl option is set to Use Glossiness. Controls the sharpness of reflection. A value of 1.0 means perfect glass-like reflection; lower values produce blurry or glossy reflections. See the Coat Glossiness example below.
Coat Roughness – Available when the Surface controlControl option is set to Use Roughness. Controls the sharpness of reflection. A value of 0.0 means perfect glass-like reflection; higher values produce blurry or glossy reflections.
Coat IOR – Specifies the Index of Refraction for the coat layer.
width5%
width30%
