This page provides information about the Blend material in V-Ray for Revit.
Section | |||||||||||||||
UI Options
Base
Coat
Override Control
Can be Overridden – When enabled, the material can be overridden when you enable the Opaque override option in the Global Overrides tab of App.Man.
Attributes
The attributes from the following expandable menus are available for the Blend material.
Anchor | ||||
Expand | |||||||||||||||||
Bump
Expand | |||||||
Contour
Expand | |||||||||||||||||||||||||||
Displacement
Raytrace Properties
Override
Material ID
