Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture (Image Added ) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
width5%10%
30%
width20%
Thumbnail
Image Removed
ThumbnailTitleTextBezier Curve
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Bezier+Curve+Correction
width10%
width30%
Image Removed
Color Correction
20%
Thumbnail
ThumbnailTitleTextColor Correction
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Color+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Map
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Mix+
width30%
Mix Map
Mix
Map
width5%10%
width5%10%
width20%30%
Thumbnail
ThumbnailTitleTextMix Operator
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Mix+Operator
width10%
30%
width20%
Thumbnail
ThumbnailTitleTextMix Value
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Mix+Value
width10%
width30%20%
Thumbnail
ThumbnailTitleTextMultiSub
Image Removed
MultiSub
width5%10%
width5%10%
width20%30%
Thumbnail
ThumbnailTitleTextSimple Mix
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Simple+Mix
width10%
width30%20%
Thumbnail
ThumbnailTitleTextSpline Curve Correction
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/Spline+Curve+
Image Removed
Spline Curve
Correction
width30%
Image Removed
TriPlanar
10%
width20%
Thumbnail
ThumbnailTitleTextTriPlanar
ThumbnailPageLinkhttps://docs.chaosgroup.com/display/VREVIT/TriPlanar
width5%10%
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailBGImageHeight250px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleHeight22%
