« Previous Version 2 Next »
This section contains details about Utility Textures found in V-Ray for Revit.
Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture ( ) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
