Section | |||||||||||||||
UI Options
Diffuse
Primary Specular
Secondary Specular
Transmission
Anchor | ||||
Options
Multipliers
Override Control
Can be Overriden – When enabled, the material can be overridden when you enable the Opaque override option in the Global Overrides tab of App.Man.
Attributes
The attributes from the following expandable menus are available for the Hair material.
Anchor | ||||
Expand | |||||||||||||||||
Raytrace Properties
Expand | ||||||||||||||||||||||
Material ID
