UI Text Box | ||
Linux: Executing V-Ray Benchmark without a flag will force its GUI to appear. If you wish to run a benchmark without the GUI, you have to specify the rendering mode explicitly in your command-line tool. |
The table below contains a list of all available options for using V-Ray Benchmark:
Option | Option alias | Function | Examples |
--dump | -d | Logs debug output | vray-benchmark-5.00.00-cli.exe --mode vray --dump |
--list-devices | -l | Lists the available devices for the picked mode | vray-benchmark-5.00.00-cli.exe --list-devices |
--with-devices DEVICES | -w DEVICES | Picks devices for rendering. DEVICES is a comma-separated list of device indices | vray-benchmark-5.00.00-cli.exe --mode vray-gpu-cuda --with-devices 0,1 |
--mode MODE | -m MODE | Picks a mode for rendering. MODE can be: vray, vray-gpu-cuda, vray-gpu-rtx. | vray-benchmark-5.00.00-cli.exe --mode vray-gpu-rtx |
--output FILE | -o FILE | Outputs the benchmark information to a .json file. FILE is an absolute path. | vray-benchmark-5.00.00-cli.exe --mode vray --output D:\CUDA_cards.json |
--version | -v | Provides information about the current version of V-Ray Benchmark. | vray-benchmark-5.00.00-cli.exe --version |
--help | -h | Displays a help message with the available command-line flags. | vray-benchmark-5.00.00-cli.exe --help |
Section | ||||||||||||||||||||||
Fancy Bullets | ||
