The V-Ray Light Mix Render Element provides adjustment control to the lights in the scene from project from inside the New V-Ray Frame Buffer.
- Add the LightMix Render Element to your sceneproject. (Settings > Channel tab > LightMix rollout).
- Then, render the sceneproject.
- In the new VFB > Layers, set the Source to LightMix.
- Now you can tweak your lights.
UI Text Box | ||
Before rendering, set your lights to white (neutral) color and boost their intensity. Rendering with lower intensity and then increasing it from the LightMix might produce noise in your render. If this happens, use the "To Scene" option and re- render the scene. |
Section | |||||||||||||||
