This page offers information on how to set up and batch render with multiple cameras with Chaos Cloud from V-Ray for 3ds Max.
Steps
width
60%
UI Text Box
type
note
This rendering approach requires the latest V-Ray 5 Update 1.
First, you have to add several cameras to your scene. Note that the current Chaos Cloud workflow is still the default workflow - i.e. Chaos Cloud renders the scene with the active view set in 3ds Max.
Press the Chaos Cloud button (Image Modified). A note that multiple cameras are available is present on the Chaos Cloud page. To render them, add the cameras from the drop-down menu. Two filters are available below the drop-down:
All - renders all cameras. Clear - clears all selected cameras and leaves the active view/perspective.
If you do not want to render the different cameras, leave the drop-down empty, and Chaos Cloud will render the job from the active view set in Render Setup > View to Render in 3ds Max.
UI Text Box
type
note
You cannot render both the active view and the cameras in one render job. However, you can clone the job and render the active view or the different cameras in the cloned job.
The camera name will be added to the name of the frames. The camera name position can be adjusted in the Naming Output convention.
The rest of the submission options are the same as the
one
ones from the Chaos Cloud page. Press the Submit button.
UI Text Box
type
note
The frame range, the aspect ratio, and the resolution are the same for all submitted cameras in one job.
If you want to render different cameras with different options, e.g. different frame range, different aspect ratio, or different resolution, clone the job and render only the needed cameras with the corresponding options.
A job with selected multiple cameras has several frames, each corresponding to a respective camera. If the job is an animation, the frames are equal to the number of frames multiplied by the number of the selected cameras. The animation job has a video preview as well.
UI Text Box
type
info
If the job is rendered with the active view, it will look as before. If it is still, it will have only one frame. If it is an animation, all frames will be listed and can be previewed individually and in a video preview.
UI Text Box
type
warning
There's a known issue for scenes containing multiple cameras and moving objects with motion blur - a render is physically correct only from the active view. In case your scene contains moving objects, re-export and submit using the active view for a correct render result.
width
5%
width
35%
Image Modified
Fancy Bullets
Standard Cameras are not supported yet.
For scenes with multiple Standard Physical cameras and Exposure control installed, the render is physically correct only if rendered with the active view.
