The Coat Reflection Render element Element is analogous to the Reflection Render Element.
The Coat Reflection Render Element RE stores indirect reflection information calculated from VRayMtl Coat Layer. Surfaces with the Coat Amount parameter set to 0 will contain no information in the render pass and will therefore render as black.
The Coat Reflection Render Element RE can be obtained by multiplying the Raw Coat Reflection by the Coat Filter. So while the raw coat reflection pass gives the full reflection of objects reflecting in the scene, the coat reflection filter sets how much of that reflection should come through in the composite. The two are multiplied together to create the Coat Reflection pass which gives a true representation of the reflection in the scene.
||Render Setup window||  > Render Elements  tab  > Add  button
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayCoatReflection
> VRayCoatReflection
width60%
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout of the (Render Setup window > V-Ray tab in the Render Setup window ) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
width5%
width35%
Image Modified
