oceanpriority – Script parameter that is 0 by default and default and can be set to 1 used for controlling which is the primary ocean container when several ones are merged together. The simulator with the highest priority will be used as Primary. The primary container provides the material and the rendering settings (the ocean level, the ocean subdivs, etc.) for the merged ocean.
Anchor | ||||
