The Refraction Render Element stores refraction information calculated from materials--such as glass or water--that refract objects behind them in the camera's view. This means the brightness, coloration, etc. of the refractions can be adjusted without the need to rerender.
Any material in a scene that has a value set for its Refraction parameter generates refraction information that can be seen in this render element. A surface with no refraction values set in its material(s) contains no information in the render element and therefore renders black.
The Refraction Render Element is a key component in the mainBeauty Elementand can easily be used to control the refractions in the Beauty composite.
The Refraction Render Element itself is already a composite of theVRayRawRefractionrender element multiplied by theVRayRefractionFilterrender element. When finer control over refractions is needed in the composite, add these additional two channels to the output along with the VRayRefraction render element channel.
