This page provides details on the uninstall process for information on how to uninstall V-Ray using the included V-Ray in Houdiniuninstaller.
The V-Ray installer will automatically uninstall uninstalls any previous versions before installing a newer version. If you need to manually uninstall V-Ray, please make sure that Houdini or V-Ray components are not being used. For silent uninstallation, see the Silent Uninstall page.
Note that uninstalling . Uninstalling V-Ray from Houdini does not uninstall the License Server. Those It can be uninstalled separately, if needed.
Windows
If you need to manually uninstall The Uninstaller originally resides in the following location - C:\Program Files\Chaos Group\V-Ray, \Houdini ##.#.###\uninstall
To access the V-Ray uninstaller from the Start menu, search for make sure that Houdini or V-Ray components are not being used. Go to Windows Start > Control Panel > Programs and Features or Start > All Programs > Chaos Group > V-Ray for Houdini >  Uninstall V-Ray for Houdini ##.#.###.
width20%
width60%
Image Added
width20%
This starts the V-Ray uninstaller. Follow the on-screen instructions to remove V-Ray from your system and restore any files overwritten by the installation.
C:\Program Files\Side Effects Software\Houdini xx##.x#.xxx###\vray
C:\Program Files\Chaos Group\V-Ray\Houdini xx##.x#.xxx###
Uninstalling the License Server
To remove the Chaos License Server, either use the Add/Remove Programs applet from the Control Panel or select Windows Start > All Programs > Chaos Group > Chaos License Server > Uninstall Chaos License Server.
Mac OS X
If you need to manually uninstall V-Ray, make sure that Houdini or V-Ray components are not being used. Double-click the Uninstaller.app program, which is normally located in /Applications/ChaosGroup/V-Ray/V-Ray for Houdini/uninstall
Linux
Uninstalling the Plug-In
To uninstall V-Ray for Houdini, start with root permissions the uninstaller program, which is normally located in the /usr/ChaosGroup/V-Ray/Houdini/uninstall/ directory, for example:
$ su
$ /usr/ChaosGroup/V-Ray/Houdini_xx##.x#.xxx###/uninstall/uninstaller
follow the instructions of the uninstaller
$ exit
