Create a V-Ray Renderer node in the out Network using one of the following ways:
  • ||out Network|| > V-Ray Renderer
  • Go to Render menu > Create Render
  • Node V-Ray
To learn how to start Interactive Production Rendering (IPR), see the Interactive Rendering page.
Image Modified
UI Text Box
typeinfo
Note that you can have multiple V-Ray Renderer and Renderer IPR nodes with different settings in a scene.
Start the rendering process in one of the following ways:
  • In the V-Ray Shelf, click on the Render button. This initiates a render process in the VFB.
  • Go to V-Ray menu > Render > V-Ray ROP
  • In the V-Ray Shelf, click on the Show VFB button. Then in the VFB, click the Render button.
  • Go to V-Ray Renderer node settings and press the Render to Disk button.
UI Text Box
typetip
If vray/vray_ipr nodes are not created in the out Network, pressing the Render button or Show VFB button on the V-Ray Shelf automatically creates them both. If necessary, the render settings can be configured.
Image Modified
Viewport Rendering
You can configure the render settings within the V-Ray Renderer node. To navigate to the specific tabs, do one of the following:
  • ||out Network|| > V-Ray Renderer node
  • Go to Render menu > Edit Render Node
  • Go to V-Ray menu > Render Settings
  • In the V-Ray Shelf, click the ROP Parm button.
For more detailed information on how to configure the IPR settings, see the Interactive Rendering page.
