Phoenix API is normally installed in the folder C:\Program Files\Chaos Group\Phoenix FD\Maya NNNN for x64\SDK where NNNN is the version of Maya (2020, 2019, etc.).
Structure
The Phoenix API includes the following folders:
Fancy Bullets | ||
Depending on the version of Maya, Phoenix API is built with the respective version of Microsoft Visual C++ Runtime:
With "/MD" Runtime Library flag.
Samples
The Phoenix API comes with two code sample projects: GridView and CSVParticles.
Prerequisites:
The project uses CMake for generating project files. Additionally the following third party libraries have been used:
GLEW (http://glew.sourceforge.net/).
GLFW (http://www.glfw.org/) Tested with GLFW Version 3.0.4.
Zlib (http://www.zlib.net/). Needed if static version of Phoenix API is being used.
GridView is a simple smoke rendering implemented in OpenGL. it is located in the \samples\GridView directory.
Prerequisites:
In order to build this sample, all external libraries must be located in a GridView/external_libs.
Build steps:
Fancy Bullets | ||
CSVParticles exports particle groups stored in Phoenix *.aur files to *.csv recognized by Thinkbox Krakatoa™ (http://www.thinkboxsoftware.com/krak-csv-file-format/).
Prerequisites:
In order to build this sample, all external libraries must be located in a CSVParticles/external_libs.
Build steps:
Fancy Bullets | ||
