This page describes the use of Batch Rendering in V-Ray for Revit.
The Batch Render option in V-Ray for Revit allows multiple renders to be rendered altogether with one button.
UI Text Box
typenote
Currently, batch rendering is supported only on the local machine and in the Cloud
How to Run Batch Rendering
width65%
1. From the drop-down menu of the View Selector, select the views you want to batch render.
width5%
width30%
Image Modified
width65%
2. Enable Auto-Save and specify the file path and type from Settings → Renderer tab → Auto-Save. Image options can be also changed. For more information, see Renderer.
width5%
width30%
Image Modified
width65%
3. After the two steps above are completed, the batch rendering can be run.
UI Text Box
typenote
V-Ray Rendering Progress window is incompatible with the Batch Render option and does not indicate any progress during batch rendering. The rendering progress should be observed through the built-in progress bar at the bottom of the VFB.
UI Text Box
typewarning
The rendering process is cancelled, if Revit is closed during batch rendering.
width5%
width30%
Image Added
How to Run Batch Rendering in Cloud
width65%
width5%
width30%
Image Added
width65%
2. Now the batch rendering can be run. Click the Cloud Batch Render button. V-Ray will export the views as .vrscenes and send them to Chaos Cloud.
width5%
width30%
Image Added
width65%
3. Sing in your Chaos Cloud account.
width5%
width30%
Image Added
width65%
4. Submit your jobs to Chaos Cloud for rendering.
width5%
width30%
Image RemovedImage Added
