width60%
On – Enables or disables the hot/dark spot.
Multiplier – Controls the strength of the hot/dark spot effect.
Hot Spot (Add) – Adds more of the Base Color in the center area of the VRaySoftBox map. The amount added corresponds to the Multiplier value. See the Hot Spot vs Dark Spot example below.
Dark Spot (Subtract) – Subtracts some of the Base Color in the center area of the VRaySoftBox map. The amount subtracted corresponds to the Multiplier value. See the Hot Spot vs Dark Spot example below.
Tint Color – When enabled from the checkbox on the right, modifies the color of the spot.
Strength – A multiplier that controls how strong the effect of the Tint Color parameter is.
Tiling Options
U/V Offset – Controls the position of the texture along the U or V axis.
U/V Tiling – When enabled, the options control the tiling of the texture along the U or V axis. See the Tiling and Outer Radius example below.
Fading Options
These options control how the hot/dark spot fades out into the base color.
Outer Radius – The outer radius where the hot spot ends as a fraction of the texture size. See the Tiling and Outer Radius example below.
Inner Radius – The inner radius where the hot spot begins to fade out as a fraction of the texture size.
Softness – Controls the rate at which the hot spot fades out.
width5%
width35%
width60%
V/U/Radial Vignette
The Gradients options allow you to blend gradient textures on top of the VRaySoftbox texture. You can add a gradient vignetting in the U and V direction, and also radially. See the V/U/Radial Vignette example below.
On – Enables the Vignette.
Flip – When enabled, the direction of the Vignette is flipped.
Gradient swatch  Use double click on the gradient swatch to add new color mark to it or refine the current mark. A set of self-explanatory options is available from the context menu.
Frame
The Frame options multiply the VRaySoftbox texture with a square shape gradient defined with the gradient swatch. See the Frame example below.
On – Enables the Frame.
Flip – When enabled, the direction of the Frame is flipped.
Tint Color – When enabled from the checkbox on the right, modifies the color of the gradient.
Noise
Adds Noise to the Frame gradient.
Amount – Controls the amount of effect the Noise has on the gradients.
Size – Changes the scale of the noise function.
Phase – Controls the speed of the noise procedural animation.
Fractal – Enables fractal noise.
Levels – Sets the levels for the fractal function.
width5%
width35%
Anchor
hotSpot
hotSpot
Example: Tiling and Outer Radius
This example shows how V-Ray Softbox tiling affects the reflection and shadow sharpness that the Area Light casts on the object as well as the scene illumination. The same effect (achieved by tweaking the tiling value) can be done by tweaking the Outer Radius of the V-Ray Softbox. The Base Color is set to black and the Tint Color is set to white in the Base Parameters.
width20%
width60%
Image slider
Panel
borderStylenone
Image Added
Tiling = 2, Outer Radius = 0.5
Panel
borderStylenone
Image Added
Tiling = 1, Outer Radius = 0.5
Panel
borderStylenone
Image Added
Tiling = 1, Outer Radius = 0.8
Panel
borderStylenone
Image Added
Tiling = 1, Outer Radius = 0.1
width20%
Anchor
darkSpot
darkSpot
Example: Hot Spot vs Dark Spot
This example shows the difference between Hot Spot and Dark Spot methods. The Base Color is grey and the Tint Color is white. The Multiplier is set to 0.1.
width20%
width60%
Image slider
afterLabelDarkSpot
startIndex1
beforeLabelHotSpot
Panel
borderStylenone
Image Added
VRaySoftBox texture with Hot Spot / Dark Spot options disabled
Panel
borderStylenone
Image Added
VRaySoftBox texture with Hot Spot option selected
Panel
borderStylenone
Image Added
VRaySoftBox texture with Dark Spot option selected
width20%
Anchor
Vignette
Vignette
Example: V/U/Radial Vignette
This example shows the effect of gradient vignetting on the final render.
width20%
width60%
Image slider
startIndex2
Panel
borderStylenone
Image Added
Vignette is off
Panel
borderStylenone
Image Added
V Vignette is on
Panel
borderStylenone
Image Added
V Vignette is on, and Flip is enabled
Panel
borderStylenone
Image Added
U Vignette is on
Panel
borderStylenone
Image Added
Radial Vignette is on
width20%
Anchor
framEx
framEx
Example: Frame
This example shows the effect of the Frame parameter. When the option is enabled, the VRaySoftBox texture is multiplied with a square shape gradient.
width20%
width60%
Image slider
startIndex1
Panel
borderStylenone
Image Added
Frames is off
Panel
borderStylenone
Image Added
Frames is on
Panel
borderStylenone
Image Added
Frames is on, Gradient is darker
width20%
