width60%
This node collects various shader nodes. It gives you control over which shader will go in the render output.
UI Expand
titleUI Path: ||mat Network|| > V-Ray > Material > V-Ray Material Output
||out Network|| > V-Ray Render Elements node > V-Ray > Material > V-Ray Material Output
||out Network|| > V-Ray Environment node > V-Ray > Material > V-Ray Material Output
Image Modified
width5%
width35%
