This page contains information about the V-Ray TexLut node.
width50%
V-Ray
TexLut is a V-
Ray utility node that allows you to apply a look up table (a .cube file) to any texture for managing resulting colors.
In the example shown, a LC3DL_Fuji3510_log2hd_ConstLmap.cube LUT file has been loaded to define the texture's look.
UI Path:
||mat Network||
 > V-Ray
> Texture:
File > V-Ray Lut
width5%
width45%
Image Added
width50%
Base Map – A slot to load the map that you want on which the LUT is going to be applied to.
LUT File – Specifies the location of the look up table.
Convert to Log Space before applying LUT – Converts the Base map to Map to a logarithmic color space before applying the look up table.
width5%
width45%
Image Modified
