width50%
The V-Ray Cellular Texture map generates a procedural cellular noise pattern.
UI Paths: ||mat Network|| V-Ray> Texture: Procedural > V-Ray Celluar
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Procedural > V-Ray Cellular
width5%
width45%
Image Modified
width50%
Type – Specifies which type to use for the Cellular texture. The choices are DotsChipsCellsChess Cells, or Plasma.
Background Color – Controls the color of the background of the Cellular procedural texture.
Center Color – Controls the color of the center of the cells.
Edge Color – Controls the color of the edges of the cells in the Cellular procedural texture.
Size – Controls the size of the Cellular procedural texture. For more details, please see the Size examples below.
Spread – Controls the spread of the procedural Cellular texture. For more details, please see the Spread examples below.
Density – Controls the Density of the Cellular texture. For more details, please see the Density examples below.
Low – Controls the low threshold (background color). For more details, please see the Low examples below.
Middle – Controls the middle threshold (edge color). For more details, please see the Middle examples below.
High – Controls the high threshold (center color). For more details, please see the High examples below.
Fractal – Enables the addition of fractal generation. Only available with Dots and Chips Types.
Fractal Iterations – Controls the number of fractal iterations. For more details, please see the Fractal Iterations examples below.
Fractal Roughness – Controls the roughness of the fractal. A value of 0.0 is very rough and a value of 1.0 is very smooth, which negates the fractal. For more details, please see the Fractal Roughness examples below.
width5%
width45%
width50%
Default Color – Specifies the color when there are no valid UVW coordinates.
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert – When enabled, inverts the resulting texture color.
width5%
width45%
width50%
Source – Specifies where the alpha channel is drawn from.:
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate – Differentiates between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabledon, the resulting texture alpha is inverted as well.
width5%
width45%
width50%
Placement Type – Specifies the way the valid portion of the texture is applied.:
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify Specifies a section of the texture using the parameters below.
Place – Allows the user to specify Specifies a section of the texture and how to place it using the parameters below.
U – Specifies the U coordinate of the valid texture sector.
V – Specifies the V coordinate of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Jitter – Controls the amount of random placement variation.
Tile U – Enables horizontal tiling.
Tile V – Enables vertical tiling.
width5%
width45%
width20%
width60%
Image slider
Panel
borderStylenone
Image Modified
Dots Size: 0.05
Panel
borderStylenone
Image Modified
 Dots Size: 0.1
Panel
borderStylenone
Image Modified
Dots Size: 0.2
Panel
borderStylenone
Image Modified
Chips Size: 0.2
Panel
borderStylenone
Image Modified
Chips Size: 0.35
Panel
borderStylenone
Image Modified
 Chips Size: 0.5
Panel
borderStylenone
Image Modified
Cells Size: 0.1
Panel
borderStylenone
Image Modified
Cells Size: 0.2
Panel
borderStylenone
Image Modified
Cells Size: 0.5
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.1
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.2
Panel
borderStylenone
Image Modified
Chess Cells Size: 0.5
Panel
borderStylenone
Image Modified
 Plasma Size: 0.05
Panel
borderStylenone
Image Modified
Plasma Size: 0.07
Panel
borderStylenone
Image Modified
Plasma Size: 0.2
Move the slider to see the example renders.
width20%
width5%
width45%
Example: Spread
Image slider
Panel
borderStylenone
Image Modified
Dots Spread: 0.5
Panel
borderStylenone
Image Modified
Dots Spread: 1.0
Panel
borderStylenone
Image Modified
 Dots Spread: 1.5
Panel
borderStylenone
Image Modified
Chips Spread: 0.5
Panel
borderStylenone
Image Modified
Chips Spread: 1.0
Panel
borderStylenone
Image Modified
 Chips Spread: 2.0
Panel
borderStylenone
Image Modified
 Cells Spread: 0.1
Panel
borderStylenone
Image Modified
 Cells Spread: 0.5
Panel
borderStylenone
Image Modified
 Cells Spread: 1.0
Panel
borderStylenone
Image Modified
Chess Cells Spread: 0.1
Panel
borderStylenone
Image Modified
Chess Cells Spread: 0.5
Panel
borderStylenone
Image Modified
 Chess Cells Spread: 0.9
Panel
borderStylenone
Image Modified
 Plasma Spread: 1.0
Panel
borderStylenone
Image Modified
Plasma Spread: 3.0
Panel
borderStylenone
Image Modified
Plasma Spread: 5.0
width45%
Example: Density
Image slider
Panel
borderStylenone
Image Modified
Dots Density: 0.1
Panel
borderStylenone
Image Modified
 Dots Density: 0.25
Panel
borderStylenone
Image Modified
Dots Density: 1.0
Panel
borderStylenone
Image Modified
Chips Density: 0.25
Panel
borderStylenone
Image Modified
Chips Density: 0.7
Panel
borderStylenone
Image Modified
Chips Density: 1.5
Panel
borderStylenone
Image Modified
Cells Density: 0.15
Panel
borderStylenone
Image Modified
Cells Density: 0.25
Panel
borderStylenone
Image Modified
 Cells Density: 0.5
Panel
borderStylenone
Image Modified
Chess Cells Density: 0.15
Panel
borderStylenone
Image Modified
 Chess Cells Density: 0.25
Panel
borderStylenone
Image Modified
Chess Cells Density: 0.5
Panel
borderStylenone
Image Modified
Plasma Density: 0.5
Panel
borderStylenone
Image Modified
 Plasma Density: 1.0
Panel
borderStylenone
Image Modified
Plasma Density: 2.0
width5%
