Filter Source – Selects what type of messages to show in the V-Ray Log Window. The render process should start at least once in order to appear in the Filter Source list.
Show All – Shows all type of messages - both NeUI and V-Ray. NeUI Main – Shows messages related to NeUI only. Remote logging service – Shows messages coming from SketchUp only. Assets preview renderer – Shows messages related to the Asset Editor's preview renderer. V-Ray – Shows messages related to V-Ray only. Asset Manager – Shows messages related to Asset Manager only.
Filter Level – Specifies whether to show all messages, only errors and warnings or only errors.
Wrap – Wraps the text.
Search bar – Allows you to search in the log by a keyword.
The Go To Log File () button opens the log file directory.
The Clear Log () button clears the V-Ray Log Window from the current messages. Using the Clear Log button with a specific source filtered clears only its log. Select the Show All option to clear everything. The Clear Log button only clears the V-Ray Log Window, the actual log text file is preserved.
