Show Controls – Opens a Toggle where you can switch on/off the V-Ray Live Link.
UI Text Box
type
tip
Right-click on the Toggle control to open the Publish to Remote Panel context menu option.
Start V-Ray Vision – Opens V-Ray Vision.
Start V-Ray Vantage - Opens V-Ray Vantage.
UI Text Box
type
note
See the In order to successfully connect to Vantage, the Live Link component's port must first be manually set to 20701. To run live link with Vision afterwards, restore the port number manually back to 54545. See Live Link from Rhinoin the Chaos Vantage docs for more informationon how to successfully setup Live Link.
Export Animation - Exports animation to V-Ray Vision. This option becomes enabled after starting V-Ray Vision.
