The Phoenix API is provided as a static and dynamic library. Depending on your project, you may pick the static or dynamic version of the library.  Usually Usually the dynamic version is preferred when there is a dependency to any version of V-Ray SDK, as Phoenix API depends on vutils_s.lib.
Fancy Bullets
typecircle
  • AURLOADER_DYNAMIC_LIB to be added the compiler settings as a preprocessor definition.
  • \lib\aurloader.lib to be added as an additional dependency to the linker.
  • \lib\aurloader.dll to be available at run time to the executable linked to \lib\aurloader.lib.
Depending on the version of Maya, Phoenix API is built with the respective version of Microsoft Visual C++ Runtime:
vc14 C++ Platform Toolset
Autodesk® Maya® 2018
Autodesk® Maya® 2019
Autodesk® Maya® 2020
Autodesk® Maya® 2022
With  for all Maya versions and for both V-Ray Next and V-Ray 5, with "/MD" Runtime Library flag.
