This page contains information about the V-Ray Invert Texture Ray TexInvert node.
width45%
The V-Ray TexInvert node Invert texture is a utility texture used to invert texture colors.
UI path: ||mat Network|| > V-Ray> Texture: Utility > V-Ray Invert
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: Utility > V-Ray Invert
width5%
width50%
 Image Modified
width50%
Texture – Specifies the texture that has its colors inverted.
Invert Alpha – When enabled, the texture alpha is inverted as well.
width5%
width45%
Image Modified
