changes.mady.by.user Gergana Lilkova
Saved on Sep 15, 2021
Saved on Nov 17, 2021
The V-Ray Scatter Volume material is designed solely as a brute force option for SSS to produce an unbiased result. When used as a base material in a Blend material it can create complex materials with a subsurface scattering base.
UI path: ||mat Network|| > V-Ray > Material > V-Ray Scatter Volume
