The V-Ray MtlWrapper can be used to specify additional surface properties per material.
UI Paths: ||mat Network|| > V-Ray > Material > V-Ray Wrapper
Node
width70%
The MtlWrapper node provides inputs for controlling various material properties. Some correspond to parameters in the section below.
base_material – Specifies the material that the additional wrapper properties are applied to.
width5%
width25%
