The Alpha channel is a grayscale image that stores the transparency of objects in the scene.
Section | |||||||||||||||
Attributes
Common Uses
The Alpha channel is primarily used as a mask to enable other elements to be placed behind the Beauty composite, such as the Background Render Element.
New Beauty composite with the Background Render Element behind the original Beauty composite
Fancy Bullets | ||
