The Noise Level Render Element shows the level of noise in the scene. It is the equivalent of the noiseLevel render element generated by theV-Ray Denoiser. Noise Level is available as a separate render element for situations where it would be useful on its own outside of the V-Ray Denoiser, such as for manual denoising or debugging purposes.
In this render element, black areas indicate no noise, white pixels indicate a great deal of noise in that area, and grey pixels indicate a moderate level of noise.
UI Path: ||out Network||> V-Ray Render Elementsnode > V-Ray > Render Channel >V-Ray Color Channel (RE)> Type > Noise Level
width
5%
width
45%
Image Modified
width
50%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings will be are applied to the current render channel.
Consider For AA– When enabled, anti-aliasing will be is used where possible.
