width50%
The Object Select Render Element stores only the object(s) called out with a specific Object or Material ID.
This effect is reversible to create a render element that excludes a particular object or objects according to Object or Material ID.
When rendering this element out, it will also include includes a filter and alpha passes separately to help make it easier to use when compositing.
UI path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Object Select (RE)
||mat Network|| > V-Ray > Render Channel > V-Ray Object Select (RE)
width5%
width45%
Image Modified
width50%
Name The text added to the end of the rendered file, when saved as a separate file.
More Than One – When enabled, more than one object is exported.
Object/Material ID – List of selected IDs included in this render pass.
Use Material IDs – When enabled, the pass considers the Material ID and renders accordingly. When disabled, these values are considered to be the Object ID.
Invert Selection – Use the opposite of the selected objects in the render pass.
Affect Matte Objects – Specifies whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material.
Denoise Enables Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
Color Mapping – When enabled, the Color Mapping options in the render settings will be are applied to the current render channel.
Deep Output – Specifies whether to include this render element in deep images.
width5%
width45%
Image Modified
Common Uses
