Chaos Cloud Batch Render Options
Section | |||||||||||||||||
Submit from V-Ray for Rhino
Submit from V-Ray for SketchUp
Submit from V-Ray for Revit
Submit Multiple Cameras from V-Ray for 3ds Max
Section | ||||||||||||||||||||||||||||||
Batch rendering with Chaos Cloud for Maya requires V-Ray 5 update 2 and Chaos Cloud 1.15 or higher. This process is available for both Maya's New Render Setup System and the Legacy Render Layers system.
Setup your scene with multiple cameras and/or render layers.
Click on the Chaos Cloud button (
). In the Submit to Chaos Cloud window, you can choose Single or Multiple Layers to render.Choose one or multiple Layers/Cameras to submit. Note that when rendering in Single Layer mode, the Current Layer option displays the layer which is rendered and all renderable cameras available in it. In Multiple layers mode, all renderable layers are displayed.
Submit your scene for render. Chaos Cloud can submit directly from Maya, when the Direct Submit Options are enabled. Otherwise, Cloud redirects to the Chaos Cloud client app, where some of the options can be adjusted.
