This page provides information about the supported features by Chaos Cloud rendering.
Chaos Cloud supports and renders scenes using both the V-Ray CPU and the V-Ray GPU engines. Chaos Cloud supports V-Ray GPU rendering running on CUDA and RTX enabled devices.
UI Text Box | ||
Please note that there are several important limitations using the V-Ray GPU engine:
UI Text Box | ||
V-Ray GPU jobs are rendered with GPU devices, but submitted scenes should not exceed 16 GB of GPU memory. Else, the jobs fail. In such cases you can use the CUDA CPU Override option and re-render the job using only CPU. |
