This This page provides information on the V-Ray Falloff texture.
Section | |||||||||||||||
Section | ||||||||||||||||||||||||||||||||
Example: Falloff Colors
This example shows how Color 1 and 2 control the range of colors for the V-Ray Falloff's gradient when the texture is mapped to the V-Ray Material Diffuse slot. Color 1 is the main color for the object, while Color 2 gives it a tint. The distribution of Color 1 and 2 can be controlled by the Falloff Type and Falloff Direction Type parameters.
Here, we've set red as Color 1 and yellow as Color 2. The Falloff Direction Type is View Z. By changing the Falloff Type, we control the gradient spread.
Section | |||||||||||||||||||||||||||||||||||||
Example: Falloff Type
This example shows how the different Falloff types affect the object's reflection.
Here, we have a V-Ray Falloff texture mapped to the Reflection color of a V-Ray Material. The Falloff Direction Type is set to View Z. Red and yellow are set as Color 1 and Color 2.
Example: IOR
This example shows how the Fresnel IOR values affect the renderer.
Here, the V-Ray Fresnel texture is mapped to the Reflection color of a V-Ray Material. Color 1 and 2 are set to red and yellow respectively. The Falloff Type is set to Fresnel, and the Falloff Distance Type is set to View Z.
Section | ||||||||||||||||||||||||||||||||||||||||||
