Section | ||||||||||||||||||||||||||||||
Common Use Examples
Example: Nightstand Lamp
In this example, the lampshade uses a Two Sided material with only a Front material connected (VRayMtl). A V-Ray sphere light is used to illuminate the inside. Translucency is shown here with grayscale values (RGB).
Section | |||||||||||||||||||||||||||||||||||||
Example: Leaf
In this example, the leaves have both front and back materials connected to the Two Sided Material. Notice how the leaves change when the Translucency value (shown in RGB) is changed. The last render uses a Translucency grayscale map.
Fancy Bullets | ||
