This page provides information on the V-Ray BRDFToonMtl node.
Section | |||||
Toon - Diffuse/Specular
Section | |||||||||||||||
Anchor | ||||
Example: Diffuse Ramp
This examples shows the effect of the Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Section | |||||||||||||||||||||||||||||||||||||||||||||
Example: Edges Override
This examples shows the effect of the Edges Override parameter. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Anchor | ||||
Example: Diffuse Color with Diffuse Ramp
This example shows the effect of the Diffuse Color when used with a Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
