3. After the two steps above are completed, the batch rendering can be run.
UI Text Box
type
note
V-Ray Rendering Progress window is incompatible with the Batch Render option and does not indicate any progress during batch rendering. The rendering progress should be observed through the built-in progress bar at the bottom of the VFB.
UI Text Box
type
warning
The rendering process is cancelled, if Revit is closed during batch rendering.
