This page provides information on what hardware and operating systems are required for Chaos Vantage to work properly.
Requirements
Please make sure that your system meets the requirements listed below before installing Chaos Vantage.
RAM | System memory should exceed GPU memory (minimum 8 GB RAM) |
Operating system | Microsoft® Windows® 10 RS5 (version 1809), update from October 2018, build 17763 or later |
Licensing | Vantage license with License Server 4.5.1 or newer |
GPU Acceleration |
UI Text Box | ||
Chaos Vantage can use up to 2 GPU devices. |
Anchor | ||||
1 – Driver 460.89 produces incorrect results in materials and textures with Ampere (30XX) cards.
Anchor | ||||
2 – GPU must be set to WDDM mode and not in TCC otherwise Chaos Vantage will not detect it.
Anchor | ||||
3 – NVIDIA AI denoiser requires driver version 466.11 and newer.
