width38%
V-Ray Node Space offers a number of nodes arranged in the following categories: Color, Distribution Context, Material Generator, Material, Math, Surface and Utility.
V-Ray offers two output (Colored Node) nodes - Material and Two Sided Material. Each Node system holds only one output (Colored) node.
Some of the nodes are texture nodes used as utility or surface maps.
UI Text Box
typenote
V-Ray Node space is available in Cinema 4D versions 21.1 and later!
UI Text Box
typeinfo
V-Ray Texture Nodes are not interchangeable or compatible with the V-Ray (Classic) Textures.
width5%
width57%
Image RemovedImage Added
Node Editor with V-Ray nodes in Cinema 4D S24R25.
How to Create Nodes
width57%
For Cinema 4D up to version S24
First, make sure you work in the V-Ray Node Space. You can select it from the drop-down menu of the Node Space option.
width5%
width38%
