UI Text Box | ||||
The License Agreement will always appear the first time you run Benchmark. Once you agree, it will not re-appear upon next launch. If you want to automate your agreement using command line, use the following commands: For Windows
For Linux
Section | |||||||||||||||
UI Text Box | ||
Linux: Executing V-Ray Benchmark without a flag will force its GUI to appear. If you wish to run a benchmark without the GUI, you have to specify the rendering mode explicitly in your command-line tool. |
The table below contains a list of all available options for using V-Ray Benchmark:
Option | Option alias | Function | Examples |
--dump | -d | Logs debug output | vray-benchmark-5.0001.0002-cli.exe --mode vray --dump |
--list-devices | -l | Lists the available devices for the picked mode | vray-benchmark-5.0001.0002-cli.exe --mode vray-gpu-cuda --list-devices |
--with-devices DEVICES | -w DEVICES | Picks devices for rendering. DEVICES is a comma-separated list of device indices | vray-benchmark-5.0001.0002-cli.exe --mode vray-gpu-cuda --with-devices 0,1 |
--mode MODE | -m MODE | Picks a mode for rendering. MODE can be: vray, vray-gpu-cuda, vray-gpu-rtx. | vray-benchmark-5.0001.0002-cli.exe --mode vray-gpu-rtx |
--output FILE | -o FILE | Outputs the benchmark information to a .json file. FILE is an absolute path. | vray-benchmark-5.0001.0002-cli.exe --mode vray --output D:\CUDA_cards.json |
--version | -v | Provides information about the current version of V-Ray Benchmark. | vray-benchmark-5.0001.0002-cli.exe --version |
--help | -h | Displays a help message with the available command-line flags. | vray-benchmark-5.0001.0002-cli.exe --help |
UI Text Box | ||
The command flags in the Option alias column in the table are shortened aliases of the commands in the Option column. You can use either of the aliases. Mixed usage is also possible, for example: vraybench_5.0001.0002-cli.exe -l --mode vray |
To run V-Ray Benchmark through the command-line interface, just pick a rendering mode or run the file (in which case the all mode will automatically be chosen).
Fancy Bullets | ||
